Virtual sectorization: design and self-optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Virtual Sectorization (ViSn) aims at covering a confined area such as a traffic hot-spot using a narrow beam. The beam is generated by a remote antenna array located at-or close to the Base Station (BS). This paper develops the ViSn model and provides the guidelines for designing the Virtual Sector (ViS) antenna. In order to mitigate interference between the ViS and the traditional macro sector covering the rest of the area, a Dynamic Spectrum Allocation (DSA) algorithm that self-optimizes the frequency bandwidth split between the macro cell and the ViS is also proposed. The Self-Organizing Network (SON) algorithm is constructed to maximize the proportional fair utility of all the users throughputs. Numerical simulations show the interest in deploying ViSn, and the significant capacity gain brought about by the self-optimized bandwidth sharing with respect to a full reuse of the bandwidth by the ViS.
vsc_od.pdf (419.57 Ko) Télécharger le fichier
hal-01131199 , version 1 (13-03-2015)
Abdoulaye Tall, Zwi Altman, Eitan Altman. Virtual sectorization: design and self-optimization. 5th International Workshop on Self-Organizing Networks (IWSON), May 2015, Glasgow, United Kingdom. ⟨10.1109/VTCSpring.2015.7146161⟩. ⟨hal-01131199⟩
Collections
INRIA INRIA2
199 Consultations
116 Téléchargements
