Nested-Unit Petri Nets: A Structural Means to Increase Efficiency and Scalability of Verification on Elementary Nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Petri nets can express concurrency and nondeterminism but not hierarchy. This article presents an extension of Petri nets, in which places can be grouped into so-called " units " expressing sequential components. Units can be recursively nested to reflect the hierarchical nature of complex systems. This model called NUPN (Nested-Unit Petri Nets) was originally developed for translating process calculi to Petri nets, but later found also useful beyond this setting. It allows significant savings in the memory representation of markings for both explicit-state and symbolic verification. Six tools already implement the NUPN model, which is also part of the next edition of the Model Checking Contest.
main.pdf (441.31 Ko) Télécharger le fichier
hal-01142198 , version 1 (14-04-2015)
Hubert Garavel. Nested-Unit Petri Nets: A Structural Means to Increase Efficiency and Scalability of Verification on Elementary Nets. 36th International Conference on Application and Theory of Petri Nets and Concurrency PETRI NETS'2015, Jun 2015, Brussels, Belgium. ⟨10.1007/978-3-319-19488-2_9⟩. ⟨hal-01142198⟩
272 Consultations
328 Téléchargements
