Safe Motion using Viability Kernels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A prerequisite to safe robot motion is to avoid Inevitable Collision States (ICS). However, the characterization of the ICS set is a challenge. Several approximation methods have been proposed, most of which either are overly conservative or fail to provide proper motion safety guarantees. In order to to improve safety guarantees, we build upon Viability Theory and adapt an algorithm designed to approximate the Viability Kernel, a concept similar to ICS. Our algorithm is applied first to a challenging static environment scenario. It is then extended to handle dynamic environments. Although it is not possible in general to ensure safety forever, we manage nonetheless to achieve infinite motion safety in two special cases.
15-icra-bouguerra-etal.pdf (402.59 Ko) Télécharger le fichier
hal-01143861 , version 1 (20-04-2015)
  • HAL Id : hal-01143861 , version 1
Bouguerra Muhammad, Thierry Fraichard, Mohamed Fezari. Safe Motion using Viability Kernels. ICRA 2015 - IEEE Int. Conf. on Robotics and Automation, May 2015, Seattle, United States. ⟨hal-01143861⟩
202 Consultations
348 Téléchargements
