DeepMatching: Hierarchical Deformable Dense Matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We introduce a novel matching algorithm, called DeepMatching, to compute dense correspondences between images. DeepMatching relies on a hierarchical, multi-layer, correlational architecture designed for matching images and was inspired by deep convolutional approaches. The proposed matching algorithm can handle non-rigid deformations and repetitive textures and efficiently determines dense correspondences in the presence of significant changes between images. We evaluate the performance of DeepMatching, in comparison with state-of-the-art matching algorithms, on the Mikolajczyk (Mikolajczyk et al 2005), the MPI-Sintel (Butler et al 2012) and the Kitti (Geiger et al 2013) datasets. DeepMatching outperforms the state-of-the-art algorithms and shows excellent results in particular for repetitive textures. We also propose a method for estimating optical flow, called DeepFlow, by integrating DeepMatching in the large displacement optical flow (LDOF) approach of Brox and Malik (2011). Compared to existing matching algorithms, additional robustness to large displacements and complex motion is obtained thanks to our matching approach. DeepFlow obtains competitive performance on public benchmarks for optical flow estimation.
paper.pdf (9.24 Mo) Télécharger le fichier
hal-01148432 , version 1 (04-06-2015)
hal-01148432 , version 2 (08-10-2015)
hal-01148432 , version 3 (31-05-2016)
Jerome Revaud, Philippe Weinzaepfel, Zaid Harchaoui, Cordelia Schmid. DeepMatching: Hierarchical Deformable Dense Matching. 2015. ⟨hal-01148432v2⟩
Collections
LJK_GI_LEAR
3032 Consultations
9185 Téléchargements
