Algebraic methods and arithmetic filtering for exact predicates on circle arcs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
The purpose of this paper is to present a new method to de- sign exact geometric predicates in algorithms dealing with curved objects such as circular arcs. We focus on the com- parison of the abscissae of two intersection points of circle arcs, which is known to be a difficult predicate involved in the computation of arrangements of circle arcs. We present an algorithm for deciding the x-order of intersections from the signs of the coefficients of a polynomial, obtained by a general approach based on resultants. This method allows the use of efficient arithmetic and filtering techniques lead- ing to fast implementation as shown by the experimental results.
hal-01179417 , version 1 (22-07-2015)
Olivier Devillers, Alexandra Fronville, Bernard Mourrain, Monique Teillaud. Algebraic methods and arithmetic filtering for exact predicates on circle arcs. Proceedings of the 16th Annual Symposium on Computational Geometry, 2000, Hong Kong, China. pp.139-147, ⟨10.1145/336154.336194⟩. ⟨hal-01179417⟩
191 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
