Elicitation of Criteria Weights Maximising the Stability of Pairwise Outranking Statements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Multi-Criteria Decision Analysis Année : 2014
We propose an indirect approach for assessing criteria-importance weights from overall outranking statements that a decision maker may acknowledge in a multiple-criteria decision aid process. Our approach takes advantage of the bipolar characteristic valuation of the overall outranking and the stability of its associated median-cut, crisp outranking relation. Numerical criteria-importance weights are inferred with the help of a mixed-integer linear programming model for which we present tests results under different configurations and tunings.
JMCDAarticle.pdf (421.33 Ko) Télécharger le fichier
hal-01185084 , version 1 (23-04-2024)
Raymond Bisdorff, Patrick Meyer, Thomas Veneziano. Elicitation of Criteria Weights Maximising the Stability of Pairwise Outranking Statements. Journal of Multi-Criteria Decision Analysis, 2014, Applying MCDA: Challenges and Case Studies, 21 (1-2), pp.113 - 124. ⟨10.1002/mcda.1496⟩. ⟨hal-01185084⟩
57 Consultations
0 Téléchargements
