Pull control for Job Shop: Holonic Manufacturing System approach using multicriteria decision-making - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Intelligent Manufacturing Année : 2012
Faced with international competition, industrial production increasingly requires implementation conditions which, in some cases, lead to seek new techniques for workshop control. This is the case when it is asked to establish Just in Time management in a Job Shop having the characteristics of working with small series. A new approach for the organization of the ‘control’ function in such a context is presented here. This approach relies on the use of the holonic paradigm on an isoarchic architecture and on a decision-making capacity based on a multicriteria analysis. The various concepts of this approach are addressed first. Then, the multicriteria decision mechanisms that are used are detailed, as well as the implementation and instrumentation phases. The first results that were obtained are presented.
JIM Pull Ounnar Pujo vHAL.pdf (720.2 Ko) Télécharger le fichier
hal-01212608 , version 1 (18-10-2015)
Fouzia Ounnar, Patrick Pujo. Pull control for Job Shop: Holonic Manufacturing System approach using multicriteria decision-making. Journal of Intelligent Manufacturing, 2012, 23 (1), pp.141-153. ⟨10.1007/s10845-009-0288-4⟩. ⟨hal-01212608⟩
104 Consultations
257 Téléchargements
