Third International Workshop on Reverse Variability Engineering (REVE 2015), associated with {SPLC} - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Roberto Erick Lopez-Herrejon
Tewfik Ziadi
Jabier Martinez
Anil Kumar Thurimella
  • Fonction : Auteur
Mathieu Acher
Variability management of a product family is the core aspect of Software Product Line Engineering. The adoption of this mature approach requires a high upfront investment before being able to automatically generate product instances based on customer requirements. However, this adoption costs and risks could be reduced with an incremental approach, which mines existing assets and then transitions to full product line engineering. Those existing assets can be for instance similar product variants that were implemented using ad-hoc reuse techniques such as clone-and-own. Hence, there is a great need of bottom-up approaches that extract variability from the artifacts (across all the life cycle) of the legacy product variants and manage the consolidated variability. The REVE workshop series aims to bring together the Reengineering and Software Product Line Engineering communities to address this gap.
Fichier non déposé
hal-01213538 , version 1 (08-10-2015)
Roberto Erick Lopez-Herrejon, Tewfik Ziadi, Jabier Martinez, Anil Kumar Thurimella, Mathieu Acher. Third International Workshop on Reverse Variability Engineering (REVE 2015), associated with {SPLC}. The 19th International Conference on Software Product Line, Jul 2015, Nashville, TN, United States. pp.394-394, ⟨10.1145/2791060.2791062⟩. ⟨hal-01213538⟩
81 Consultations
0 Téléchargements
