A Monte Carlo estimation of the mean residence time in cells surrounded by thin layers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We present a new Monte Carlo method to estimate the mean-residence time of a diffusive particle in a domain surrounded by a thin layer of low diffusivity. Through a homogenization technique, the layer is identified with a membrane. The simulations use a stochastic process called the snapping out Brownian motion the density of which matches suitable transmission conditions at the membrane. We provide a benchmark test which is a simplified form of a real-life problem coming from brain imaging techniques. We also provide a new algorithm to adaptively estimate the exponential rate of the tail of the distribution function of the probability to be in the domain using Monte Carlo simulations.
snob-mcm2015-R2.pdf (330.55 Ko) Télécharger le fichier
hal-01216471 , version 1 (16-10-2015)
hal-01216471 , version 2 (23-10-2015)
hal-01216471 , version 3 (15-12-2015)
hal-01216471 , version 4 (12-09-2016)
hal-01216471 , version 5 (12-05-2017)
hal-01216471 , version 6 (11-06-2017)
Copyright (Tous droits réservés)
  • HAL Id : hal-01216471 , version 5
Antoine Lejay. A Monte Carlo estimation of the mean residence time in cells surrounded by thin layers. 2015. ⟨hal-01216471v5⟩
502 Consultations
423 Téléchargements
