On nontraditional quasi-geostrophic equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2016
In this article, we work on nontraditional models where the so-called traditional approximation on the Coriolis force is removed. In the derivation of the quasi-geostrophic equations, we obtain new terms in δ/ε, where δ (aspect ratio) and ε (Rossby number) are both small numbers. We provide here some rigorous crossed-asymptotics with regards to these parameters , prove some mathematical and physical results on the nontraditional models, and situate them among traditional ones.
NonTraditionalModels-M2AN.pdf (480.87 Ko) Télécharger le fichier
hal-01232740 , version 1 (10-02-2011)
hal-01232740 , version 2 (11-02-2011)
hal-01232740 , version 3 (18-04-2011)
hal-01232740 , version 4 (25-03-2015)
hal-01232740 , version 5 (24-11-2015)
hal-01232740 , version 6 (01-06-2016)
hal-01232740 , version 7 (27-01-2017)
  • HAL Id : hal-01232740 , version 6
Carine Lucas, James C. Mcwilliams, Antoine Rousseau. On nontraditional quasi-geostrophic equations. ESAIM: Mathematical Modelling and Numerical Analysis, 2016. ⟨hal-01232740v6⟩
956 Consultations
819 Téléchargements
