Special weak Dirichlet processes and BSDEs driven by a random measure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
This paper considers a forward BSDE driven by a random measure, when the underlying forward process X is special semimartingale, or even more generally, a special weak Dirichlet process. Given a solution (Y, Z, U), generally Y appears to be of the type u(t, X_t) where u is a deterministic function. In this paper we identify Z and U in terms of u applying stochastic calculus with respect to weak Dirichlet processes.
E_FR_corrente2.pdf (352.98 Ko) Télécharger le fichier
hal-01241076 , version 1 (09-12-2015)
hal-01241076 , version 2 (16-12-2016)
Elena Bandini, Francesco Russo. Special weak Dirichlet processes and BSDEs driven by a random measure. 2015. ⟨hal-01241076v1⟩
249 Consultations
196 Téléchargements
