Correctly Rounded Arbitrary-Precision Floating-Point Summation
We present a fast algorithm together with its low-level implementation of correctly rounded arbitrary-precision floating-point summation. The arithmetic is the one used by the GNU MPFR library: radix 2; no subnormals; each variable (each input and the output) has its own precision. We also describe how the implementation is tested.
mpfr-sum.pdf (130.02 Ko)
Télécharger le fichier
annex.zip (96.19 Ko)
