Shape Analysis for Unstructured Sharing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shape analysis aims to infer precise structural properties of imperative memory states and has been applied heavily to verify safety properties on imperative code over pointer-based data structures. Recent advances in shape analysis based on separation logic has leveraged sum-marization predicates that describe unbounded heap regions like lists or trees using inductive definitions. Unfortunately, data structures with un-structured sharing, such as graphs, are challenging to describe and reason about in such frameworks. In particular, when the sharing is unstructured, it cannot be described inductively in a local manner. In this paper, we propose a global abstraction of sharing based on set-valued variables that when integrated with inductive definitions enables the specification and shape analysis of structures with unstructured sharing.
sharing-sas15.pdf (586.93 Ko) Télécharger le fichier
hal-01249418 , version 1 (01-01-2016)
Huisong Li, Xavier Rival, Bor-Yuh Evan Chang. Shape Analysis for Unstructured Sharing. SAS 2015 - 22nd International Symposium on Static Analysis, Sep 2015, Saint-Malo, France. pp.90-108, ⟨10.1007/978-3-662-48288-9_6⟩. ⟨hal-01249418⟩
237 Consultations
202 Téléchargements
