Smoothed complexity of convex hulls by witnesses and collectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Geometry Année : 2016
We present a simple technique for analyzing the size of geometric hypergraphs dened by random point sets. As an application we obtain upper and lower bounds on the smoothed number of faces of the convex hull under Euclidean and Gaussian noise and related results.
265-1014-1-PB.pdf (1.13 Mo) Télécharger le fichier
Format : Figure, Image
hal-01285120 , version 1 (08-03-2016)
Olivier Devillers, Marc Glisse, Xavier Goaoc, Rémy Thomasse. Smoothed complexity of convex hulls by witnesses and collectors. Journal of Computational Geometry, 2016, 7 (2), pp.101-144. ⟨10.20382/jocg.v7i2a6⟩. ⟨hal-01285120⟩
576 Consultations
263 Téléchargements
