Interval observer for SIR epidemic model subject to uncertain seasonality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The issue of state estimation is considered for a SIR model with seasonal variations and uncertainties in the transmission rate. Assuming continuous measurement of the number of new infectives per unit time, a class of interval observers with estimate-dependent gain is constructed, and asymp-totic error bounds are provided. Mathematics Subject Classification (2000) Primary 92D30; Secondary 34C12, 93B07, 93D09, 93D30
posta2016_def.pdf (270.69 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01309743 , version 1 (30-04-2016)
hal-01309743 , version 2 (26-11-2016)
  • HAL Id : hal-01309743 , version 2
Pierre-Alexandre Bliman, Bettina D 'Avila Barros. Interval observer for SIR epidemic model subject to uncertain seasonality. Positive Systems - POSTA 2016, Sep 2016, Roma, Italy. ⟨hal-01309743v2⟩
279 Consultations
143 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
