Object classification via planar abstraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a supervised machine learning approach for classification of objects from sampled point data. The main idea consists in first abstracting the input object into planar parts at several scales, then discriminate between the different classes of objects solely through features derived from these planar shapes. Abstracting into planar shapes provides a means to both reduce the computational complexity and improve robustness to defects inherent to the acquisition process. Measuring statistical properties and relationships between planar shapes offers invariance to scale and orientation. A random forest is then used for solving the multiclass classification problem. We demonstrate the potential of our approach on a set of indoor objects from the Princeton shape benchmark and on objects acquired from indoor scenes and compare the performance of our method with other point-based shape descriptors.
object_classification.pdf (2.82 Mo) Télécharger le fichier
Format : Figure, Image
hal-01318637 , version 1 (19-05-2016)
  • HAL Id : hal-01318637 , version 1
Sven Oesau, Florent Lafarge, Pierre Alliez. Object classification via planar abstraction. ISPRS congress, Jul 2016, Prague, Czech Republic. ⟨hal-01318637⟩
298 Consultations
908 Téléchargements
