Enhancement of breathing simulation using individual lobe segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2016
Pierre-Emmanuel Leni
  • Fonction : Directeur scientifique
  • PersonId : 934005
To tackle thorax movement from CT images, we have developed a platform to simulate a customized breathing cycle, where the pulmonary movement has been considered only at the rough border of the whole lung by artificial neural networks (ANN). The goal of this work is to include additional information of the lung lobe. Thus, more ANN will be used and future simulation will be able to take into consideration the impact of tumor on lobe movement. We present a new automatic segmentation algorithm that enables the extraction of lobar contour data using sliding mask and direction estimation. These improvements enhance the overall system performance in which higher precision and more accurate treatments can be expected.
hal-01386113 , version 1 (22-10-2016)
Intuon Lertrusdachakul, Pierre-Emmanuel Leni, Régine Gschwind (Dir.). Enhancement of breathing simulation using individual lobe segmentation. 124 ( 00005), pp.9, 2016, EPJ Web of Conferences, ⟨10.1051/epjconf/201612400005⟩. ⟨hal-01386113⟩
63 Consultations
0 Téléchargements
