Cooperative concurrent asynchronous computation of the solution of symmetric linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Algorithms Année : 2016
This paper extends the idea of Brezinski's hybrid acceleration procedure, for the solution of a system of linear equations with a symmetric coefficient matrix of dimension n, to a new context called cooperative computation , involving m agents (m n), each one concurrently computing the solution of the whole system, using an iterative method. Cooperation occurs between the agents through the communication, periodic or probabilistic, of the estimate of each agent to one randomly chosen agent, thus characterizing the computation as concurrent and asynchronous. Every time one agent receives solution estimates from the others, it carries out a least squares computation , involving a small linear system of dimension m, in order to replace its current solution estimate by an affine combination of the received estimates, and the algorithm continues until a stopping criterion is met. In addition , an autocooperative algorithm, in which estimates are updated using affine combinations of current and past estimates, is also proposed. The proposed algorithms are shown to be efficient for certain matrices, specifically in relation to the popular Barzilai–Borwein algorithm, through numerical experiments.
Cooperative2.pdf (644.21 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01395756 , version 1 (11-11-2016)
Amit Bhaya, Pierre-Alexandre Bliman, Fernando Pazos. Cooperative concurrent asynchronous computation of the solution of symmetric linear systems. Numerical Algorithms, 2016, ⟨10.1007/s11075-016-0213-9⟩. ⟨hal-01395756⟩
216 Consultations
200 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
