Backward Stochastic Differential Equations with no driving martingale, Markov processes and associated Pseudo Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Adrien Barrasso
  • Fonction : Auteur
  • PersonId : 997955
Francesco Russo
We investigate existence and uniqueness for a new class of Backward Stochastic Differential Equations (BSDEs) with no driving martingale. When the randomness of the driver depends on a general Markov process X those BSDEs are denominated forward BSDEs and can be associated to a deter-ministic problem, called Pseudo-PDE which constitute the natural generalization of a parabolic semilinear PDE which naturally appears when the underlying filtration is Brownian. We consider two types of solutions for the Pseudo-PDEs: classical and of martingale type.
BSDENoMart.pdf (613.32 Ko) Télécharger le fichier
hal-01431559 , version 1 (11-01-2017)
hal-01431559 , version 2 (07-03-2017)
hal-01431559 , version 3 (24-12-2017)
Adrien Barrasso, Francesco Russo. Backward Stochastic Differential Equations with no driving martingale, Markov processes and associated Pseudo Partial Differential Equations: Backward Stochastic Differential Equations with no driving martingale. 2017. ⟨hal-01431559v1⟩
198 Consultations
213 Téléchargements
