Hindrances to bistable front propagation: application to Wolbachia invasion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We study the biological situation when an invading population propagates and replaces an existing population with different characteristics. For instance, this may occur in the presence of a vertically transmitted infection causing a cytoplasmic effect similar to the Allee effect (e.g. Wolbachia in Aedes mosquitoes): the invading dynamics we model is bistable. After quantification of the propagules, a second question of major interest is the invasive power. How far can such an invading front go, and what can stop it? We rigorously show that a heterogeneous environment inducing a strong enough population gradient can stop an invading front, which will converge in this case to a stable front. We characterize the critical population jump, and also prove the existence of unstable fronts above the stable (blocking) fronts. Being above the maximal unstable front enables an invading front to clear the obstacle and propagate further. We are particularly interested in the case of artificial Wolbachia infection, used as a tool to fight arboviruses.
wave-blocking-NSV.pdf (719.95 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01442291 , version 1 (20-01-2017)
Grégoire Nadin, Martin Strugarek, Nicolas Vauchelet. Hindrances to bistable front propagation: application to Wolbachia invasion. 2017. ⟨hal-01442291⟩
863 Consultations
149 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
