ReactiveML, a Reactive Extension to ML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Louis Mandel
  • Fonction : Auteur
  • PersonId : 996112
Marc Pouzet
  • Fonction : Auteur
  • PersonId : 969936
We present ReactiveML, a programming language dedicated to the implementation of complex reactive systems as found in graphical user interfaces, video games or simulation problems. The language is based on the reactive model introduced by Boussinot. This model combines the so-called synchronous model found in Esterel which provides instantaneous communication and parallel composition with classical features found in asynchronous models like dynamic creation of processes.The language comes as a conservative extension of an existing call-by-value ML language and it provides additional constructs for describing the temporal part of a system. The language receives a behavioral semantics á la Esterel and a transition semantics describing precisely the interaction between ML values and reactive constructs. It is statically typed through a Milner type inference system and programs are compiled into regular ML programs. The language has been used for programming several complex simulation problems (e.g., routing protocols in mobile ad-hoc networks).
Fichier non déposé
hal-01489747 , version 1 (14-03-2017)
Louis Mandel, Marc Pouzet. ReactiveML, a Reactive Extension to ML. PPDP 2005 - ACM International Conference on Principles and Practice of Declarative Programming, Jul 2005, Lisboa, Portugal. pp.82-93, ⟨10.1145/1069774.1069782⟩. ⟨hal-01489747⟩
84 Consultations
0 Téléchargements
