Self-organized pattern formation of run-and-tumble chemotactic bacteria: Instability analysis of a kinetic chemotaxis model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Collective motion of chemotactic bacteria as E. Coli relies, at the individual level, on a continuous reorientation by runs and tumbles. It has been established that the length of run is decided by a stiff response to temporal sensing of chemical cues along the pathway. We analyze consequences on self-organized pattern formation resulting from modulation of tumbling frequency with stiff response. Thanks to both analytical arguments and numerical simulations, we show that the stationary homogeneous state of population density is destabilized in realistic ranges of parameters. A remarkable property is that the unstable frequencies remain bounded, as it is the case in Turing instability. These theoretical developments are in accordance with several biological observations.
preprint.pdf (515.92 Ko) Télécharger le fichier
hal-01494963 , version 1 (24-03-2017)
hal-01494963 , version 2 (12-01-2018)
Benoît Perthame, Shugo Yasuda. Self-organized pattern formation of run-and-tumble chemotactic bacteria: Instability analysis of a kinetic chemotaxis model. 2017. ⟨hal-01494963v1⟩
1104 Consultations
313 Téléchargements
