2-D Analytical Investigation of the Parameters and the Effects of Magnetization Patterns on the Performance of Coaxial Magnetic Gears - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Electrical Systems in Transportation Année : 2017
In this Paper, a 2-D analytical model has been presented for coaxial magnetic gears. Based on Maxwell's equations the extracted model has been obtained via the solution of the Laplace and Poisson equations by using the separation of variable technique for each sub-region (internal and external magnets, internal and external air-gap and slots). Then the integral coefficients of the general solutions have been obtained by using the boundary conditions and continuity between sub-regions. The proposed analytical model can be used as a tool for design and optimization of magnetic gears. The influences of the number of pole-pair, the magnetization pattern, the size of slot-opening and the segment ratio of the two-segment Halbach pattern on the transmitted torque and unbalanced magnetic forces (UMFs) have been analytically investigated. Finally, to illustrate the efficacy of the proposed model, the analytical results of the magnetic field distribution, transmitted torque and unbalanced magnetic force have been compared with those obtained from finite element analyses.
Paper_IET.pdf (1.21 Mo) Télécharger le fichier
hal-01499355 , version 1 (31-03-2017)
A. Rahideh, A. A. Vahaj, M. Mardaneh, T. Lubin. 2-D Analytical Investigation of the Parameters and the Effects of Magnetization Patterns on the Performance of Coaxial Magnetic Gears. IET Electrical Systems in Transportation, 2017, ⟨10.1049/iet-est.2016.0070⟩. ⟨hal-01499355⟩
122 Consultations
204 Téléchargements
