Blind Modulation Classification for Cognitive Satellite in the Spectral Coexistence Context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2017
The scarcity of the usable satellite spectrum has led to a need for advanced communication techniques. Among them, multi-satellite networks have been promoted for their ability to reuse the frequency bands in a more aggressive manner. This is made possible by sharing both the spectral and spatial degrees of freedom. Meanwhile, the concept of Cognitive Satellite (CS) was deeply investigated to make the best of these novel architectures. In this context, very few blind signal processing methods were proposed to tackle the co-channel interference issues entailed by such systems. Herein, we develop a novel low-complexity algorithm for blind Automatic Modulation Classification (AMC) and parameters estimation in the strongly interfering scenario. The proposed method rely on an Analytical study of the Mth-Power non-linear Transformation (AMPT) of the co-channel mixture. Theoretical analysis and extensive simulations show the effectiveness of the proposed method in various scenarios.
IEEE_TSP_2017_VG_JP_SD.pdf (973.79 Ko) Télécharger le fichier
hal-01513362 , version 1 (25-04-2017)
Vincent Gouldieff, Jacques Palicot, Steredenn Daumont. Blind Modulation Classification for Cognitive Satellite in the Spectral Coexistence Context. IEEE Transactions on Signal Processing, 2017, 65 (12), pp.3204-3217. ⟨10.1109/TSP.2017.2688976⟩. ⟨hal-01513362⟩
173 Consultations
708 Téléchargements
