Monotone Simultaneous Paths Embeddings in $\mathbb{R}^d$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We study the following problem: Given $k$ paths that share the same vertex set, is there a simultaneous geometric embedding of these paths such that each individual drawing is monotone in some direction? We prove that for any dimension $d\geq 2$, there is a set of $d + 1$ paths that does not admit a monotone simultaneous geometric embedding.
paths-embeddings.pdf (357.49 Ko) Télécharger le fichier
Format : Figure, Image
hal-01529154 , version 1 (30-05-2017)
hal-01529154 , version 2 (03-01-2018)
  • HAL Id : hal-01529154 , version 1
David Bremner, Olivier Devillers, Marc Glisse, Sylvain Lazard, Giuseppe Liotta, et al.. Monotone Simultaneous Paths Embeddings in $\mathbb{R}^d$. 2017. ⟨hal-01529154v1⟩
693 Consultations
1000 Téléchargements
