Internal Models and Anticipations in Adaptive Learning Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2003
The explicit investigation of anticipations in relation to adaptive behavior is a recent approach. This chapter first provides psychological background that motivates and inspires the study of anticipations in the adaptive behavior field. Next, a basic framework for the study of anticipations in adaptive behavior is suggested. Different anticipatory mechanisms are identified and characterized. First fundamental distinctions are drawn between implicit anticipatory behavior, payoff anticipatory behavior, sensory anticipatory behavior, and state anticipatory behavior. A case study allows further insights into the drawn distinctions. Many future research direction are suggested.
hal-01532236 , version 1 (02-06-2017)
Martin V. Butz, Olivier Sigaud, Pierre Gérard. Internal Models and Anticipations in Adaptive Learning Systems. Anticipatory Behavior in Adaptive Learning Systems, 2684, Springer, pp.86-109, 2003, Lecture Notes in Computer Science, ⟨10.1007/978-3-540-45002-3_6⟩. ⟨hal-01532236⟩
62 Consultations
0 Téléchargements
