Equivalent Stress Model for Magnetic Hysteresis Losses Under Biaxial Loading - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2014
The concept of equivalent stress for hysteretic behaviour is discussed. Magnetic measurements are first performed on iron-silicon thin sheets submitted to biaxial stress. Both anhysteretic and dissipative magnetic responses are recorded. An anhysteretic equivalent stress for the magnetic susceptibility is first applied. A configuration effect allows building an equivalent stress for the coercive field. The combination of the two formulations leads to a prediction of losses in the stress plane.
SMM21_rekik_v5.pdf (285.29 Ko) Télécharger le fichier
hal-01532889 , version 1 (04-06-2017)
Mahmoud Rekik, Laurent Daniel, Olivier Hubert. Equivalent Stress Model for Magnetic Hysteresis Losses Under Biaxial Loading. IEEE Transactions on Magnetics, 2014, 50, pp.1 - 4. ⟨10.1109/TMAG.2013.2285241⟩. ⟨hal-01532889⟩
230 Consultations
204 Téléchargements
