AspectTAZ: A New Approach based on Aspect-Oriented Programming for Object-Oriented Industrial Messaging Services Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Luc Teboul
  • Fonction : Auteur
Lionel Seinturier
  • Fonction : Auteur
  • PersonId : 970094
Renaud Pawlak
  • Fonction : Auteur
Eric Gressier-Soudan
Erwan Becquet
  • Fonction : Auteur
Since 1994, we have designed and prototyped several industrial messaging services over different platforms. Our experiments have been based on the ISO-MMS standard and TASE.2. This paper describes lessons learned from these projects, and some of our activities in designing the next generation of industrial messaging services. Faced with the fast changing world of communication protocols, a stringent requirement for these services is to be easily adaptable to new protocols (ONC-RPC and CORBA in the past, now SOAP/XML). Recent software engineering research introduced the notion of aspect-oriented programming (AOP) to cope with such a need in adaptability. This paper demonstrates the viability of this approach in addressing our requirement.
hal-01544513 , version 1 (21-06-2017)
Luc Teboul, Lionel Seinturier, Renaud Pawlak, Eric Gressier-Soudan, Erwan Becquet. AspectTAZ: A New Approach based on Aspect-Oriented Programming for Object-Oriented Industrial Messaging Services Design. 4th IEEE International Workshop on Factory Communication Systems (WFCS 2002), Aug 2002, Vasteras, Sweden. pp.165-171, ⟨10.1109/WFCS.2002.1159714⟩. ⟨hal-01544513⟩
42 Consultations
0 Téléchargements
