Analysis of Duobinary Encoding for CPM Signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we investigate the effect of using a duobinary encoder on binary continuous phase modulations (CPM). This technique transforms the binary symbols into ternary ones using a specific mapping and has been adopted for linear modulation schemes. We show that applying this encoder to binary CPM increases the spectrum efficiency of the signal and keeps a theoretical bit error rate performance close to the binary case.
Mots clés
Fichier non déposé
hal-01547655 , version 1 (27-06-2017)
  • HAL Id : hal-01547655 , version 1
Rami Othman, Yves Louët, Alexandre Skrzypczack. Analysis of Duobinary Encoding for CPM Signals. URSI General Assembly and Symposium 2017, URSI, Aug 2017, Montréal, France. ⟨hal-01547655⟩
135 Consultations
0 Téléchargements
