Multi-scale spot segmentation with selection of image scales - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Detecting spot-like objects of different sizes in images is needed in many applications. Multiple image scales must then be handled for reliable spot segmentation. We define an original criterion based on the a contrario approach and the LoG scale-space framework to automatically select the meaningful scales. We then design a coarse-to-fine multi-scale spot segmentation scheme involving a locally adaptive thresholding across scales, to come up with the final map of segmented spots. We report experimental results on simu-lated and real images of different types, and we demonstrate that our method outperforms other existing methods.
Fichier non déposé
hal-01561164 , version 1 (12-07-2017)
Bertha Mayela Toledo Acosta, Antoine Basset, Patrick Bouthemy, Charles Kervrann. Multi-scale spot segmentation with selection of image scales. ICASSP 2017 - The 42nd IEEE International Conference on Acoustics, Speech and Signal Processing, Mar 2017, New Orleans, United States. pp.5, ⟨10.1109/ICASSP.2017.7952489⟩. ⟨hal-01561164⟩
Collections
INRIA INRIA2
93 Consultations
0 Téléchargements
