The Halfspace Matching Method: a New Method to Solve Scattering Problem in Infinite Media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We are interested in acoustic wave propagation in time harmonic regime in a two-dimensional medium which is a local perturbation of an infinite isotropic or anisotropic homogeneous medium. We investigate the question of finding artificial boundary conditions to reduce the numerical computations to a neighborhood of this perturbation. Our objective is to derive a method which can extend to the anisotropic elastic problem for which classical approaches fail. The idea consists in coupling several semi-analytical representations of the solution in halfspaces surrounding the defect with a Finite Element computation of the solution around the defect. As representations of the same function, they have to match in the infinite intersections of the halfspaces. It leads to a formulation which couples, via integral operators, the solution in a bounded domain including the defect and its traces on the edge of the halfspaces. A stability property is shown for this new formulation.
BBDFT_V1.pdf (1.52 Mo) Télécharger le fichier
hal-01561339 , version 1 (12-07-2017)
hal-01561339 , version 2 (25-07-2017)
hal-01561339 , version 3 (22-11-2018)
  • HAL Id : hal-01561339 , version 1
Anne-Sophie Bonnet-Ben Dhia, Sonia Fliss, Antoine Tonnoir. The Halfspace Matching Method: a New Method to Solve Scattering Problem in Infinite Media. 2017. ⟨hal-01561339v1⟩
367 Consultations
272 Téléchargements
