Modular Causality in a Synchronous Stream Language
This article presents a causality analysis for a synchronous stream language with higher-order functions. This analysis takes the shape of a type system with rows. Rows were originally designed to add extensible records to the ML type system (Didier Rémy, Mitchell Wand). We also restate briefly the coiterative semantics for synchronous streams (Paul Caspi, Marc Pouzet), and prove the correctness of our analysis with respect to this semantics.
