Dynamic Wrappers: Handling the Composition Issue with JAC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Renaud Pawlak
  • Fonction : Auteur
Lionel Seinturier
  • Fonction : Auteur
  • PersonId : 970094
Laurence Duchien
Gérard Florin
  • Fonction : Auteur
Modern applications, and especially distributed ones, need flexibility and dynamic evolution. These goals can be partially reached with separation of concerns. However, a static approach is not sufficient when trying to get dynamic adaptation during the application execution-time. We present the JAC (Java Aspect Components) framework that meets dynamic adaptation by using the notions of dynamic wrappers in order to achieve separation of concerns for non-functional programs, and of wrapping controllers to implement the composition of wrappers (maybe coming from different programmers) at wrap-time and at call-time.
Fichier non déposé
hal-01572041 , version 1 (04-08-2017)
Renaud Pawlak, Lionel Seinturier, Laurence Duchien, Gérard Florin. Dynamic Wrappers: Handling the Composition Issue with JAC. TOOLS 2001 - 39th International Conference and Exhibition Technology of Object-Oriented Languages and Systems, Jul 2001, Santa Barbara, CA, United States. pp.56-65, ⟨10.1109/TOOLS.2001.941659⟩. ⟨hal-01572041⟩
30 Consultations
0 Téléchargements
