A Framework for Real-Time Communication Based Object Oriented Industrial Messaging Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Lionel Seinturier
  • Fonction : Auteur
  • PersonId : 970094
André Laurent
  • Fonction : Auteur
Bruno Dumant
  • Fonction : Auteur
Eric Gressier-Soudan
François Horn
  • Fonction : Auteur
The goal of the ongoing project described in this paper is to provide an object oriented real-time industrial messaging service on top of a Quality of Service (QoS) aware Object Request Broker (ORE) with real time network communications. Our project has investigated object oriented solutions for industrial messaging services. The corresponding prototype offers a portable object oriented industrial messaging service implemented in Java. We have built a QoS aware extension of this service based on Jonathan, a flexible ORE that allows the introduction of temporal QoS to handle real time constraints. The full prototype is based on the AJAX toolkit, our binding factory for ATM networks.
Fichier non déposé
hal-01574378 , version 1 (14-08-2017)
Lionel Seinturier, André Laurent, Bruno Dumant, Eric Gressier-Soudan, François Horn. A Framework for Real-Time Communication Based Object Oriented Industrial Messaging Services. 7th IEEE International Conference on Emerging Technologies and Factory Automation (ETFA'99), Oct 1999, Barcelona, Spain. pp.805-814, ⟨10.1109/ETFA.1999.813076⟩. ⟨hal-01574378⟩
30 Consultations
0 Téléchargements
