Qualitative Symbolic Perturbation: Two Applications of a New Geometry-based Perturbation Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Geometry Année : 2017
In a classical Symbolic Perturbation scheme, degeneracies are handled by substituting some polynomials in ε for the inputs of a predicate. Instead of a single perturbation, we propose to use a sequence of (simpler) perturbations. Moreover, we look at their effects geometrically instead of algebraically; this allows us to tackle cases that were not tractable with the classical algebraic approach.
qsp.pdf (2.57 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
Format Figure, Image
hal-01586511 , version 1 (12-09-2017)
Olivier Devillers, Menelaos Karavelas, Monique Teillaud. Qualitative Symbolic Perturbation: Two Applications of a New Geometry-based Perturbation Framework. Journal of Computational Geometry, 2017, 8 (1), pp.282--315. ⟨10.20382/jocg.v8i1a11⟩. ⟨hal-01586511⟩
289 Consultations
134 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
