Characterization and Preparation of Wood-Furanic Foams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Renewable Materials Année : 2014
Fine wood powder/furanic foams were prepared with a strong predominance of the wood component. Low weight and density are important properties of foamed composites. Focusing on preparing light materials, wood foam composites were made using a chemical foaming method and expanded using diethyl ether as the foaming agent. The additives were added to note their effect on the density and mechanical properties, like impact strength and Young's moduli, of the expanded composites. Various tests and scanning electron microscopy analysis were also performed. The foaming agent resulted in closed cells with varied sizes and more or less regular shapes, and with significant density reductions and acceptable loss of mechanical properties.
Fichier non déposé
hal-01597093 , version 1 (28-09-2017)
V. K. Srivastava, A. Pizzi. Characterization and Preparation of Wood-Furanic Foams. Journal of Renewable Materials, 2014, 2 (3), pp.201-206. ⟨10.7569/JRM.2014.634107⟩. ⟨hal-01597093⟩
22 Consultations
0 Téléchargements
