A Meta-Object Protocol for Distributed OO Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
Lionel Seinturier
  • Fonction : Auteur
  • PersonId : 970094
Laurence Duchien
Gérard Florin
  • Fonction : Auteur
The design of complex distributed object applications such as transactional systems (e.g. nested transactions, two or three phase commit protocols), network algorithms (e.g. routing, spanning tree construction, group causal delivery) or cooperative applications is a hard task. We present a meta-object protocol (MOP) called CAO-LAC, to assist developers in implementing these applications. A prototype was developed for the language of the GUIDE distributed object system. The MOP uses a state/transition approach to synchronize concurrent objects. We propose some extensions to manage intra-object parallelism. Then we report on a spanning tree construction algorithm that was implemented with this MOP.
Fichier non déposé
hal-01623805 , version 1 (25-10-2017)
Lionel Seinturier, Laurence Duchien, Gérard Florin. A Meta-Object Protocol for Distributed OO Applications. TOOLS 23 - Technology of Object-Oriented Languages and Systems, Aug 1997, Santa Barbara, CA, United States. pp.306-317, ⟨10.1109/TOOLS.1997.654738⟩. ⟨hal-01623805⟩
29 Consultations
0 Téléchargements
