A Time Gap-Based Spacing Policy for Full-Range Car-Following - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Carlos Flores
  • Fonction : Auteur
  • PersonId : 1022764
Vicente Milanés
  • Fonction : Auteur
  • PersonId : 973904
Car-following systems aim to improve safety and comfort whereas increasing traffic throughput. These techniques follow a spacing policy that determines how the ego-vehicle tracks its preceding one. This paper proposes a spacing policy to maximize the traffic throughput and reduce the inter-vehicle distances without losing safety and ensuring the string stability. A variable time gap policy is developed for low speeds, yielding the same dynamic response for high speeds and shorter spacing gaps. Simulations and real platforms' experiments are shown to validate the proposed approach.
ITSC17_Spacing.pdf (420.41 Ko) Télécharger le fichier
hal-01634494 , version 1 (14-11-2017)
  • HAL Id : hal-01634494 , version 1
Carlos Flores, Vicente Milanés, Fawzi Nashashibi. A Time Gap-Based Spacing Policy for Full-Range Car-Following. Intelligent Transportation Systems Conference 2017, Oct 2017, Yokohama, Japan. ⟨hal-01634494⟩
381 Consultations
1803 Téléchargements
