Stabilization of switched affine systems with disturbed state-dependent switching laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2018
In this paper we investigate the stabilization problem for a class of switched affine systems with a state-dependent switching law. Since the states measurements are in general subject to perturbations and noises, we propose a robust switching law design method. Qualitative conditions for the stability of the closed-loop switched system are given. Stability conditions are also formulated as Linear Matrix Inequalities (LMIs) in order to allow numerical implementations. Results are illustrated by numerical examples in order to show the efficiency of the method and its limits.
IJRNC2017.pdf (594.35 Ko) Télécharger le fichier
hal-01689247 , version 1 (23-02-2018)
Zohra Kader, Christophe Fiter, Laurentiu Hetel, Lotfi Belkoura. Stabilization of switched affine systems with disturbed state-dependent switching laws. International Journal of Robust and Nonlinear Control, 2018, 28 (2), pp.582-595. ⟨10.1002/rnc.3887⟩. ⟨hal-01689247⟩
343 Consultations
475 Téléchargements
