A NURBS-BASED TOPOLOGY OPTIMIZATION METHOD INCLUDING ADDITIVE MANUFACTURING CONSTRAINTS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, the Solid Isotropic Material with Penalization (SIMP) topology optimization (TO) method is revisited and reformulated within the mathematical framework of NURBS functions. This implies several advantages: firstly, a NURBS surface allows exploiting an implicitly defined filter zone; secondly, the number of optimization variables (i.e. the parameters defining the NURBS surface) is relatively small when compared to the classical SIMP approach. Finally the TO can be carried out by including non-linearity (either geometric or material) or non-conventional manufacturing constraints, as those related to the Additive Manufacturing (AM) technology. In this work the TO is applied to a standard benchmark.
I2M_ ECCM_2017_COSTA,.pdf (1.55 Mo) Télécharger le fichier
hal-01695683 , version 1 (29-01-2018)
  • HAL Id : hal-01695683 , version 1
  • ENSAM : http://hdl.handle.net/10985/12539
Giulio Costa, Marco Montemurro, Jérôme Pailhès. A NURBS-BASED TOPOLOGY OPTIMIZATION METHOD INCLUDING ADDITIVE MANUFACTURING CONSTRAINTS. 7th International Conference on Mechanics and Materials in Design, Jun 2017, Albufeira, Portugal. pp.63. ⟨hal-01695683⟩
210 Consultations
338 Téléchargements
