Wind estimation algorithm for quadrotors using detailed aerodynamic coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In the context of safe control of quadrotors, wind velocity estimation and compensation have a key-role. For this reason, assuming the lack of airspeed sensors and considering sensors noise, in this paper three time-varying parameter estimation algorithms are introduced, studied and merged to estimate the varying wind velocity, using only on-board quadrotor sensors and an inertial tracking position system (e.g. Optitrack camera, GPS). To this end, a detailed quadrotor flight dynamics model is presented using identified aerodynamic coefficients and wind velocity components along the three axes. Then, a decomposition of dynamical equations is performed in known and unknown terms to be estimated. Thanks to this decomposition, the estimation algorithms are built and finally tested and validated in numerical experiments, against the introduced sensors' noise.
sample.pdf (868.86 Ko) Télécharger le fichier
hal-01703084 , version 1 (07-02-2018)
  • HAL Id : hal-01703084 , version 1
Gabriele Perozzi, Denis Efimov, Jean-Marc Biannic, Laurent Planckaert, Patricia Coton. Wind estimation algorithm for quadrotors using detailed aerodynamic coefficients. ACC 2018 - American Control Conference, Jun 2018, Milwaukee, WI, United States. ⟨hal-01703084⟩
Collections
ONERA INRIA INRIA2
472 Consultations
738 Téléchargements
