Heuristic approach for forecast scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Hind Zaaraoui
  • Fonction : Auteur
  • PersonId : 974187
Zwi Altman
  • Fonction : Auteur
  • PersonId : 872996
Eitan Altman
  • Fonction : Auteur
  • PersonId : 830042
Tania Jimenez
Forecast Scheduling (FS) is a scheduling concept that utilizes rate prediction along the users' trajectories in order to optimize the scheduler allocation. The rate prediction is based on Signal to Interference plus Noise Ratio (SINR) or rate maps provided by a Radio Environment Map (REM). The FS has been formulated as a convex optimization problem namely the maximization of an α−fair utility function of the cumulated rates of the users along their trajectories [1]. This paper proposes a fast heuristic for the FS problem based on two FS users' scheduling. Furthermore, it is shown that in the case of two users, the FS problem can be solved analytically, making the heuristic computationally very efficient. Numerical results illustrate the throughput gain brought about by the scheduling solution.
Forecast Scheduling Fast Heuristics_IWSON.pdf (347.51 Ko) Télécharger le fichier
hal-01705829 , version 1 (09-02-2018)
  • HAL Id : hal-01705829 , version 1
Hind Zaaraoui, Zwi Altman, Sana Ben Jemaa, Eitan Altman, Tania Jimenez. Heuristic approach for forecast scheduling. IWSON 2018 - 7th International Workshop on Self-Organizing Networks, Apr 2018, Barcelona, Spain. pp.1-6. ⟨hal-01705829⟩
149 Consultations
247 Téléchargements
