On distance-preserving elimination orderings in graphs: Complexity and algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 2018
For every connected graph G, a subgraph H of G is isometric if the distance between any two vertices in H is the same in H as in G. A distance-preserving elimination ordering of G is a total ordering of its vertex-set V (G), denoted (v 1 , v 2 ,. .. , v n), such that any subgraph G i = G\(v 1 , v 2 ,. .. , v i) with 1 ≤ i < n is isometric. This kind of ordering has been introduced by Chepoi in his study on weakly modular graphs [11]. We prove that it is NP-complete to decide whether such ordering exists for a given graph — even if it has diameter at most 2. Then, we prove on the positive side that the problem of computing a distance-preserving ordering when there exists one is fixed-parameter-tractable in the treewidth. Lastly, we describe a heuristic in order to compute a distance-preserving ordering when there exists one that we compare to an exact exponential time algorithm and to an ILP formulation for the problem.
dpo-hal.pdf (633.57 Ko) Télécharger le fichier
hal-01741277 , version 1 (22-03-2018)
David Coudert, Guillaume Ducoffe, Nicolas Nisse, Mauricio Soto. On distance-preserving elimination orderings in graphs: Complexity and algorithms. Discrete Applied Mathematics, 2018, 243, pp.140-153. ⟨10.1016/j.dam.2018.02.007⟩. ⟨hal-01741277⟩
239 Consultations
267 Téléchargements
