On Necessary and Sufficient Conditions for Fixed-Time Stability of Continuous Autonomous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Necessary and sufficient conditions for fixed-time stability of continuous autonomous system are given. Continuity of the settling-time function is considered and a characterization of fixed-time stability with continuous settling-time function is presented. Further refinements of these conditions that allow more constructive calculations are provided. Several academic examples are provided to illustrate the theoretical results.
ECC18_Paco_A.pdf (509.91 Ko) Télécharger le fichier
hal-01755079 , version 1 (30-03-2018)
  • HAL Id : hal-01755079 , version 1
Francisco Lopez-Ramirez, Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti. On Necessary and Sufficient Conditions for Fixed-Time Stability of Continuous Autonomous Systems. Proc. 17th European Control Conference (ECC), Jun 2018, Limassol, Cyprus. ⟨hal-01755079⟩
250 Consultations
686 Téléchargements
