Delaunay Triangulations of Points on Circles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Delaunay triangulations of a point set in the Euclidean plane are ubiquitous in a number of computational sciences, including computational geometry. Delaunay triangulations are not well defined as soon as 4 or more points are concyclic but since it is not a generic situation, this difficulty is usually handled by using a (symbolic or explicit) perturbation. As an alternative , we propose to define a canonical triangulation for a set of concyclic points by using a max-min angle characterization of Delaunay triangulations. This point of view leads to a well defined and unique triangulation as long as there are no symmetric quadruples of points. This unique triangulation can be computed in quasi-linear time by a very simple algorithm.
circleDelaunay-arXiv.pdf (599.7 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
Format Figure, Image
hal-01780607 , version 1 (27-04-2018)
Vincent Despré, Olivier Devillers, Hugo Parlier, Jean-Marc Schlenker. Delaunay Triangulations of Points on Circles. 2018. ⟨hal-01780607⟩
301 Consultations
56 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
