Reducing Affective Responses to Surgical Images through Color Manipulation and Stylization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Lonni Besançon
Amir Semmo
  • Fonction : Auteur
  • PersonId : 1008855
David J. Biau
  • Fonction : Auteur
  • PersonId : 840709
Rabah Taouachi
  • Fonction : Auteur
Tobias Isenberg
Pierre Dragicevic
We present the first empirical study on using color manipulation and stylization to make surgery images more palatable. While aversion to such images is natural, it limits many people's ability to satisfy their curiosity, educate themselves, and make informed decisions. We selected a diverse set of image processing techniques, and tested them both on surgeons and lay people. While many artistic methods were found unusable by surgeons, edge-preserving image smoothing gave good results both in terms of preserving information (as judged by surgeons) and reducing repulsiveness (as judged by lay people). Color manipulation turned out to be not as effective.
Informatique
Besancon_2018_RAR.pdf (36.11 Mo) Télécharger le fichier
Besancon_2018_RAR-2.pdf (167.99 Ko) Télécharger le fichier
Format : Figure, Image
hal-01795744 , version 1 (18-05-2018)
hal-01795744 , version 2 (14-06-2018)
hal-01795744 , version 3 (18-06-2018)
hal-01795744 , version 4 (19-06-2018)
Lonni Besançon, Amir Semmo, David J. Biau, Bruno Frachet, Virginie Pineau, et al.. Reducing Affective Responses to Surgical Images through Color Manipulation and Stylization. Proceedings of the Joint Symposium on Computational Aesthetics, Sketch-Based Interfaces and Modeling, and Non-Photorealistic Animation and Rendering, Aug 2018, Victoria, Canada. pp.4:1--4:13, ⟨10.1145/3229147.3229158⟩. ⟨hal-01795744v2⟩
1032 Consultations
746 Téléchargements
