Generalized compressible flows and solutions of the H(div) geodesic problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Archive for Rational Mechanics and Analysis Année : 2020
We study the geodesic problem on the group of diffeomorphism of a domain M⊂Rd, equipped with the H(div) metric. The geodesic equations coincide with the Camassa-Holm equation when d=1, and represent one of its possible multi-dimensional generalizations when d>1. We propose a relaxation à la Brenier of this problem, in which solutions are represented as probability measures on the space of continuous paths on the cone over M. We use this relaxation to prove that smooth H(div) geodesics are globally length minimizing for short times. We also prove that there exists a unique pressure field associated to solutions of our relaxation. Finally, we propose a numerical scheme to construct generalized solutions on the cone and present some numerical results illustrating the relation between the generalized Camassa-Holm and incompressible Euler solutions.
RelaxationCamassaHolm_final2.pdf (1.14 Mo) Télécharger le fichier
hal-01815531 , version 1 (26-06-2018)
hal-01815531 , version 2 (04-09-2018)
hal-01815531 , version 3 (07-10-2019)
Thomas Gallouët, Andrea Natale, François-Xavier Vialard. Generalized compressible flows and solutions of the H(div) geodesic problem. Archive for Rational Mechanics and Analysis, 2020, 235, pp.1707-1762. ⟨10.1007/s00205-019-01453-x⟩. ⟨hal-01815531v3⟩
432 Consultations
237 Téléchargements
