Multiple layers of contrasted images for robust feature-based visual tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Feature-based SLAM (Simultaneous Localization and Mapping) techniques rely on low-level contrast information extracted from images to detect and track keypoints. This process is known to be sensitive to changes in illumination of the environment that can lead to tracking failures. This paper proposes a multi-layered image representation (MLI) that computes and stores different contrast-enhanced versions of an original image. Keypoint detection is performed on each layer, yielding better robustness to light changes. An optimization technique is also proposed to compute the best contrast enhancements to apply in each layer. Results demonstrate the benefits of MLI when using the main keypoint detectors from ORB, SIFT or SURF, and shows significant improvement in SLAM robustness.
MLI_ICIP2018_FinalVersion.pdf (1.69 Mo) Télécharger le fichier
hal-01822789 , version 1 (25-06-2018)
Xi Wang, Marc Christie, Eric Marchand. Multiple layers of contrasted images for robust feature-based visual tracking. ICIP’18 - 25th IEEE International Conference on Image Processing, Oct 2018, Athens, Greece. pp.241-245, ⟨10.1109/ICIP.2018.8451810⟩. ⟨hal-01822789⟩
350 Consultations
362 Téléchargements
