The non-linear sewing lemma II: Lipschitz continuous formulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We give an unified framework to solve rough differential equations. Based on flows, our approach unifies the former ones developed by Davie, Friz-Victoir and Bailleul. The main idea is to build a flow from the iterated product of an almost flow which can be viewed as a good approximation of the solution at small time. In this second article, we give some tractable conditions under which the limit flow is Lipschitz continuous and its links with uniqueness of solutions of rough differential equations. We also give perturbation formulas on almost flows which link the former constructions.
non-linear-sewing-lemma-II-v2.pdf (419.85 Ko) Télécharger le fichier
hal-01839202 , version 1 (13-07-2018)
hal-01839202 , version 2 (26-10-2018)
hal-01839202 , version 3 (08-02-2021)
Antoine Brault, Antoine Lejay. The non-linear sewing lemma II: Lipschitz continuous formulation. 2018. ⟨hal-01839202v2⟩
Collections
UNIV-COTEDAZUR
484 Consultations
863 Téléchargements
