On dynamical feedback control design for generalized homogeneous differential inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In the present paper, the stability criterion for generalized homogeneous differential inclusions is obtained that may simplify the control design procedure in some particular cases. Robust dynamical feedback control law is designed for homogeneous differential inclusions. Performance of the resulting dynamical feedback is illustrated by numerical simulation.
Automatique
CDC_paper.pdf (212.24 Ko) Télécharger le fichier
hal-01872548 , version 1 (12-09-2018)
  • HAL Id : hal-01872548 , version 1
Konstantin Zimenko, Andrey Polyakov, Denis Efimov. On dynamical feedback control design for generalized homogeneous differential inclusions. CDC 2018 - 57th IEEE Conference on Decision and Control, Dec 2018, Miami Beach, United States. ⟨hal-01872548⟩
Collections
INRIA INRIA2
54 Consultations
159 Téléchargements
